FOUR WINNS 5.0 OMC COBRA ENGINE DIES
esovine
I have a 1995 Four Winns 190 Horizon I/O with a 5.0 OMC Cobra Engine. They engine will unexpectedly and abruptly cut off while cruising along (3,000 RPM). After it cuts off, when I turn the key nothing happens. It doesn't seem to have any power going to the starter/engine. However, I still have power to trim the prop out of the water and the other auxillary switches work (i.e., blower, bilge, etc.) and the battery has 12.3 Volts of charge. The first time it happen I let it sit overnight messed around with the engine wires, etc and it started right up. Any ideas what the problem may be? Thanks
