Four Winns Throttle Problems
amjnj
Hey all! I just purchased a 1992 Four Winns 190 Horizon. Beautiful boat runs great, sounds great, but with one small problem. The throttle or gears are having a hard time going into neutral. I’m a first time boat owner so this problem and others are all new to me. When I pull up to the dock, or anywhere; I have to pull back on the throttle or jerk really hard to get it to pop out of gear. When I do so, it goes into reverse. I then have to pop it back out of reverse and it goes directly into forward. I play this game for about 5 minutes until I get it docked or loaded. PLEASE HELP. I really appreciate it!!
SpinnerBait_Nut
Re: Four Winns Throttle Problems
Welcome to iboats.<br />Is this and I/O or a outboard engine?
SpinnerBait_Nut
Ok, let's get this to theI/O forum for answers.
Lou C
Either that or a sticky transom shift cable, the area in the pivot housing where the bell crank is gets mineral deposits and can stop the bellcrank from moving smoothly.
tim10034
had the same problem....trimming down all the way helps out a little bit changed the shift cable solved the problem but after a year or so problem it came back...seems to me that the shift cable keeps getting kinked i wish i could order one where it wouldnt kink and rust out
amjnj
Thanks everyone for the replys! Does anyone know where I can order a repair manual for a OMC cobra?
