FP623 / 072107 michigan wheel prop questions
mangus
Hello all, I need this prop for my 1988 Force 125 HP outboard and 17' boat.
Priced one out for $200 locally, am prepared to order as it seems to be a fairly unique prop for this motor. Can do a lil better on the Net but prefer to shop locally.
Any alternatives out there? I saw an adapter kit that allows one to run other props.
Current prop is damaged beyond repair.
Thanks for any help.
Mangus
180shabah
Re: FP623 / 072107 michigan wheel prop questions
have you checked props here at iboats?
Slip Away
The 072107 is a 13.25" x 17 pitch RH rotation Michigan Match 3 blade Aluminum that is an exact replacement for your engine. That would be the correct prop.
