freebetonys turbo
damie
Just lookig at freebeetonys thread on turbo chargers, does anyone know of a kit that will fit to the 4.3lx 1999 190hp mercruiser?<br />bondo, you seem to know all about turbos, have you come across anyone that has had this done before?
crazy charlie
Re: freebetonys turbo
Marine engines work very hard compared to auto engines because of the constantly higher rpms.I dont see a marine engine lasting very long being turbo charged.Charlie
tommays
turbos are very common on marine diesel but not done on curent gas motors<br /><br />you wont find any off the shelf systems made for marine use only one offs custom made<br /><br />the main problem is that a gas has a ingition point off 853 deg F and in general all the parts off a system are not suposed to go above about 25% of this point about 220 deg f to be safe its why your exaust system manifolds are water cooled <br /><br />tommays
FreeBeeTony
Any other opinions on turbo charging a gas marine engine? I am still considering it and want to know as much as I can before I do it........<br />Why would the operating temp go up? It's not re-circulating the exhaust gases.
tommays
i cant rattel off the exact reg but on land or sea enclosed areas with fumes have almost the same rules about heat<br /><br />its has to due with keeping the temp in the engine bay at a safe level a tubro will raise the temp unless the area has been built to allow the nessary air flow to keep it at that temp<br /><br />i dont know how they water cool the tubro but keeping the surface temp of the tubros parts at a safe level is a big issue <br /><br />tommays
FreeBeeTony
This "rig" is specifically deisgned for a Mercruiser I/O application, so I was told.
tommays
tony<br /><br />i am not trying to stop you as yours is made for a merc and it should be fine<br /><br /> but telling mariah 18 why he wont find any current bolt on tubros<br /><br />saftey rules allways change as new things are learned i dont think you see tubros on current boats because its cheaper to put in a big block than build a tubro system that will meet the current saftey rules<br /><br />tommays
FreeBeeTony
ok.....<br />prior to this i never even heard of a turbocharger for a boat!<br /><br />if i can get it for the right price I still may give it a try.<br /><br />one thing concerns me.....parts availablity.<br /><br />tony<br /><br />ps.....not trying to steal/interupt this thread...just saw my name and was curious!
bluewater19
Look guys, <br />a turbo's compressor side is only going to get as hot as the exhaust gs going through it. That is why it gets very hot on a car. In your I/O application it is not going to get that hot because of the cooling in the manifold and riser.<br />They used to make a system like this for 3.0's back in the 80's. <br />Don't worry about the heat Tony. Go for it and let us know how it turns out!
TwoBallScrewBall
How is a turbo going to react to water, especially salt water, flowing through it? Or will the turbo somehow have the water separated from the exhaust? Maybe the turbo goes between the riser and manifold so it can pull straight exhaust without water? But I would think that the element of high heat is then a problem unless the turbo is water cooled. You got any pictures or literature you can post on that setup Tony? Just curious about it.
tommays
the motor is going to be same as before the water and exaust will mix at the ellbow looking at tonys pictures the tubro seams to be water cooled to control surface temps<br /><br />tommays
TwoBallScrewBall
I just searched and found the other turbo post with the ebay auction. That's a slick setup. Honestly though, seems like a lot of work for 15% HP gain. Would bring a 165 to about 190HP. Cheaper than a V6 though! If it went for the price that auction ended at I'd have jumped on it! (If I had an IL6)
Peter J Fraser
Depending on the turbo used (make / model) most can be fitted with a water cooled exhaust turbine housing which the water flows through before passing into the exhaust riser / difuser housing.<br />If you are able to get a 'wet' turbine housing then your heat problem will be no worse than at present.<br />I would lag the turbo with a heat insulating blanket also.<br />You would only need 4 - 6 psi boost to get a huge improvement in efficiency.<br />A factory marine engine will already have hardened exh valve seats and good quality valve materials and should cope with a mild turbo without problems.<br />The engines are low enough in the compression ratio that an improvement in the air flow efficiency gained from boosting shouldn't adversely affect engine life.<br />Why not contact some one like Gale Banks who make a living from such work.<br /><br />Thats my thoughts anyway.<br /><br />Peter
damie
Thanks guys!<br />hey that supercharger sounds a good idea!<br />anyone know about those?
ziggy
heres some more food for thought. just read a artical about turbos and superchargers. sorry but the artical was regaurding pwc, 4 stoke non the less though. the talk was about the fact that compression ratios are lower in turbo and supercharged engins. apperently the reason being that the high compression engine, when supercharged or turbo'd can lead to detonation. and that don't sound good to me, i would find out any more thoughts on this before i'd do a turbo to my toy. and actually they do make one, can get a supercharger for my fx140.it's made for my specific toy, but not by yamaha. still designed for that toy. i aint up for it either i don't think. the supercharged seadoos and and turbo'd polaris and hondas have a ratio of 8:1 or round abouts compared to my plain fuel injected yamaha at darn near 12:1. I wonder what the compression ratio of a 165 mercruiser is? i got one of those too, just don't seem like a engine that has much hope for HP upgrades. but it is a great work engine and long lived. i'm for keepin it stock for relaiablilty reasons at this point unless i knew more about the ramification of this detonation situation. jim
tommays
i think your going to find that most engines just fit under there cover and there is no room to even work on them let alone add anything that that would take up space like a supercharger<br /><br /><br />tommays
Don S
Cabin fever must be setting in early this year. Turbo's and superchargers on OLD engines????? Seems like a lot of expense for little gain, and the gain probably won't even be felt in a "Real Life" situation.
FreeBeeTony
They sold it out from under me! And I was looking forward to it!<br /><br />Oh well............it was funwhile it lasted!
ron7000
Banned
Originally posted by FreeBeeTony:<br /> Any other opinions on turbo charging a gas marine engine? I am still considering it and want to know as much as I can before I do it........<br />Why would the operating temp go up? It's not re-circulating the exhaust gases.
for what I know, trying to "turbo" charge a marine engine is not worth it. For one, if they do make a water cooled turbo it's bad from a standpoint of efficiency. There's an inherent exhaust gas temp drop across the turbine inlet and outlet ports, due to the compressor converting that energy into work (giving you boost on the engine intake). So the hotter the exhaust gas, the better the flow and the better the boost and efficiency. Now if you water cool the turbo to reduce heat, you reduce boost and it's efficiency... probably to the point where it's not that beneficial. Of course you can design the compressor to partially compensate for that, but in the end, you're wasting energy. Hopefully I didn't butcher that explaination too much, I sit next to fluid dynamics guys at work that can talk for hours about this stuff. If I can, I'll post a better explaination.<br />Probably because of the whole heat issue, engine bay enclosure along with turbo design and efficiency, is why you see no turbo systems for boats these days and why their life in the marine market was shortlived. Along with that, turbo-charging a carbureted motor is not that easy. The entire carburetor has to have the intake plenum coming from the compressor completely around it and sealed off. With intake manifold geometries and finishes, it's not easy to get a good seal. And when the seal fails, the carb cannot monitor fuel properly and the engine will run poorly. Not to mention there's no way to tune the carb while the engine is running, along with having to possibly resize the entire carb, and definitely jets and power valves and fuel delivery to accomodate the increased fuel need of the motor. If you don't, the motor runs lean, detonates, and burns valves and pistons. On top of all that, there's turbo lag- where the boost doesn't kick in until the engine is under load at a certain rpm to produce enough exhaust gas to spin the compressor blades to produce boost. So now you have to tune the carb for that.<br />In freebeetony's ebay link of the turbo for sale, I don't see any hardware of the intake plenum going from the turbo to the carb. That there would probably cost more than the turbo itself, if you could even find one or have one made. As for the motor it goes on, I'm not familiar with it but I imagine you either replace the entire exhaust manifold with one that re-routes exhaust gas to the turbo then back to the manifold/riser to accomodate the compressor, or the compressor somehow fits between the manifold and rise to get access to exhaust gas flow.<br /><br />"super"-chargers on the other hand, are a different story. The Weiand-root type blowers (fit on top of or replace the intake manifold, what you see on NHRA top-fuel drags) are best for running with carbs and can be tuned. These are the same type Merc uses on their big block race motors found in Fountains. Although now I think these use throttle-body fuel injection and a computer to do the fuel mapping as opposed to straight carb tuning- would give better idle and overall performance in all temperature & sea conditions.<br />There's also centifigual type superchargers- about the size of an alternator, bolt on front of engine and utilize crank pulley belt to spin. They are probably the easiest to install, but for same reasons as a turbocharger, are no good on a carb'd motor because they too are located upstream of the carb and thus requires the entire carb to be sealed off from atmospheric pressure and must only see the boost pressure- the 14.7psi atmosphere + x psi boost, to meter fuel properly.<br /><br />hope this helps, I think you're better off passing on the ebay auction.
