Freeing a Salt Water Prop Hub.
Doh
Ok I am a fresh water boater, that has purchased a prop, from a salt water boater.
The Migigan Wheel hub is stuck in the Prop. I have tried (as hard as I feel good about) to flip it over and hammer it out with a punch. No effect it didn't even budge.
It is the right hub for my boat, so installing it and running it (in fresh water) is a possibility, but I would like to sell the prop next spring if it doesn't work out.
Any hints?
Thanks
Re: Freeing a Salt Water Prop Hub.
Ayuh,... My guess is, it's a Pressed in Hub that isn't supposed to be changed...
Doh
Ayuh,... So Run it, then if you wish, sell it....With the hub In it...
