Freeze Crack on outdrive can it be welded or Marine Tex
Can this freeze crack be welded or should I attempt marine tex? When I dropped the outdrive there was plenty of good oil in it but. Fresh Water came out of the lowest drain screw by the propeller and water came out of the port surrounded by the orange oring in this pic what is this hole for how would water get into the lowest part of the outdrive cavity that the propeller gears are in ?
Kens%20Boat%20Page.html
Re: Freeze Crack on outdrive can it be welded or Marine Tex
Sorry I think if you paste this in a browser you can see th pictures I was refering to people.bu.edu/nesllyc/Kens%20Boat%20Page.html
Haut Medoc
Can't see it...<br />Doubtful if it can be fixed....<br />If you search you will find the proper way to post pics on this forum...Then you will get a better response..JK
Any time Water is introduced to the Drive oil cavity,... It'll settle to the Bottom of that cavity...... It's Heavier than Oil.....<br /><br />Even without seeing your picture,.... I Doubt Epoxy is going to Fix it,...<br />And,.. Without a Tear-Down,..... Welding Rarely Works.......<br />A New or Replacement Housing is Usually the Only Answer........<br /><br />Besides,..... The Gears have been sitting in Water all winter,+ are Probably Rusted by now........<br />Which Probably means they're Junk as Well........
