Re: Fresh Water Flush
There's this little trick I learnt from a Boat Fishing mag. You fill a 4/5 gallon drum with water, fit it with a short hose and muffs. Now this can be used to start up the outboard while the boat is still on the trailer on top of the ramp, if something's wrong with the outboard, you save yourself the troubles of ,aunching and then retrieving the boat. Generally the water in the drum is good for 10+ mins, I would thought that should be enough to flush the outboard.
