Fresh water pump?
garbageguy
24 ft cruiser fresh water system. Pump builds intermittent pressure, plumbing is good, suspect it's the little diaphragm pump. Agree? Other things to consider? Source for replacement pump? Pump-replacing tips? Click image for larger version  Name:	pumps (1).jpg Views:	2 Size:	64.1 KB ID:	10555898
pump close-up Click image for larger version  Name:	fresh water pump (1).jpg Views:	1 Size:	58.3 KB ID:	10555897
tpenfield
Usually those pumps fail after 5-10 years. So, yes, probably the pump.
You can Google your way to replacement sources. It looks like the 2088-423-344 pump is no longer available (?) and a 4138-111-E65 may be a replacement.
Installation is easy as long as you get good access to the fittings. Don't over tighten them upon installation.
garbageguy
Thanks tp.
Are the new pumps' higher gpm and pressure just a bonus, and due to the fact the company is making (or is having made) more efficient, "better" pumps now - and increases from original spec are OK?
Recommend Shur-flo, or other?
tpenfield
I would not go too high in pressure. For example, the original pump is 45 psi and 2.8 gal/min flow rate. You could go to 55 psi and a higher flow rate, but I would be concerned about going to the 65+ psi range, as your plumbing may not like the extra pressure.
