Weathersbytaylor
- Mar 12, 2017
- 19
After finding a wiped cam lobe, I went in and rebuilt the entire engine (new pistons, bearings, etc). Engine has roughly 10 hours on it total now including about 4 hours blasting around the lake. Completed the break in oil change and noticed that the engine was developing a low end knock. Didn't hear it before the full day at the lake. It appears a few minutes after starting the engine and is noticeable until about 2500 rpm when it's drowned out by engine noise. It's not as loud as other engines with spun rods that I have heard and is not noticeable when the engine compartment door is shut. Pulled #4 spark plug and the noise goes away. I'm thinking I may have caught whatever the issue is fairly early. My question is how likely is it that a rod has spun a bearing? any other things I should check while the pan is off? Gonna pull the pan tonight to find out. Oil filter didn't have any observable metal in it. What's the easiest way to differentiate piston slap vs rod knock? Thanks for any input guys
1996 mercruiser 3.0lx.
