fried temp sending unit, any ideas?
Dan Beisel
I'm in the process of putting back together a 1970 Johnson 115hp (V-4) motor that was overheated. My problem is, the temp sending unit was fried out beyond use. It is the little wire that is embedded in rubber that fits into a hole on the side of a head. My parts supplier (usually very resourceful) says the part isn't available.<br /><br />Does anybody have any ideas out there? I was thinking of adding a temp gauge (the warning light worked but isn't real effective). If so, how should I rig it up and/or fill in the little hole on the side of the head?<br /><br />Thanks in advance,<br />Dan
JB
Re: fried temp sending unit, any ideas?
Moving to JohnnyRude troubles
