From forward To reverse no neutral
tigerhack
boat on trailer just decide to run it for a bit ,when try to shift gears it shift from forward straight to reverse,no neutral what is happening here ....:rolleyes:
Re: From forward To reverse no neutral
Ayuh,........
It's because you have the Wrong Distributer,+ It's Not hooked up to the Shift Switch......
Haut Medoc
But it will go in neutral with the engine off, correct?......;)
Haut Medoc
For some reason your interrupter switch is not functioning.....
You will need to determine whether it is the swich itself, the electrical connections or a bad shift cable.....;)
HoeMedo,....
Search up Tigerhack,..... He's posted pictures of the Mess he's got.....
It's a Non-Marine Carb, Dist, Etc.......
That's Why I said what I did up in post #2......
