From Johnson to Merc
macdaddy
I am switching motors from a blown up 1994 Johnson 70 to a late 80's Mercury 85.
I want to use all the controls from the Johnson on the Merc, my question is what do I do about the main wiring plug? Are the wires color coded the same on both makes?
I have the Merc controls but the one on the boat is alot nicer.
Thanks in advance, this site has help me so much in the past.
jerryjerry05
Re: From Johnson to Merc
The wiring was standardized I think in the late 70's but your not gonna make a direct swap.The shifter won't work and it would be a lot easier to use the Merc.J
Wingedwheel
You should be able to find a set of controls on Craigslist pretty reasonable, but Jerry's right, the cables won't work.
macdaddy
Thanks, thats what I thought.
I have the controls for the Merc.
Thanks again.
