front motor mount for inline 6 chevy
acammelleri
I have replaced the block with a new and cannot figure out the the right side of the motor mount. The left side is fine there is not a bracket on the other side to attach. Can anyone find a diagram of how this is supposed to be attached. I have looked all over the internet and in the manual. This is the driver side of the motor....<br /><br />PLEASE help me! :eek:
Alumarine
Re: front motor mount for inline 6 chevy
Does it look like this?<br /><br />
acammelleri
yes it does<br />but its the other side i cannot figure out near the oil filter. Can you take some more pictures of the other side?<br />Thanks a bunch!
gspig
mine looks similar. the right side bolts directly to the block. the left side (shown above) bolts to the block, but there is a thick spacer that the bolt pass through.
Alumarine
Sorry, boats at lake I'm not.<br />If I go out this weekend I'll take a picture.<br />That was an old picture I had on file.
acammelleri
The other side of the motor doesnt have a bracket or anything to bolt the engine mount on. I do have the side with the altenator on correct but cant figure out the other. Its sitting on the engine mount but not secure.<br />Any help is appriciated.<br />Thanks for your time.
Alumarine
These are the best pictures I have of the left mount. Hope they help. I didn't have my camera at the lake.<br />
<br />
acammelleri
Is there a seprate piece that the bolt goes through on that side? The block on mine has the hole and then the mount has the two bolts but nothing to attach to. Im at my witts end this is all I need to get my boat out in the water.<br /><br />I know I know you have to be smarter than the boat.<br /><br />Any help is appriciated. Thanks
Alumarine
On my 140 the starboard mount bolts directly to a flange that is part of the block.
joe marino
I just did the same thing what i did was put the mount on ( the alternator side line it up so the bottom ear on the mountis against the block there is two holes in the mount.hole on the hole farthest from the front of the engine drill into the block and tap it. on the hole closest to the front there is a large 5/8 hole in the block I made a bushing (have a lathe) that reduced it to 3/8 then drilled and tapped the mount. you may have to shim between the mount and the block because the mount doesnt fit flush against the block around .025 of an inch. check this before you torque the bolts down or you may snap the ear off.
Bt Doctur
sounds like the block does not have the correct casting.Most car blocks did not have this. chevy vans and chevy II s used blocks with this casting.Motors got to come back out.
