Front Motor Mount Replacement - 1987 120HP
canufixit
HI,<br /><br />I see that my forn mount has sagged and I'm planning on replacing the front motor mount... After I support the engine and remove the mounting cross arm - I think the mount is pressed in ??? My motor / mount is clean an not rusty aor anything ... I have a smapp hyd press - is this going to be the repair from hell - or will this mount just tap out wiht a hammer ??<br /><br />Thanks all for the help - Love the board !!!<br /><br />SteveC
Twidget
Re: Front Motor Mount Replacement - 1987 120HP
Hi Steve, welcome aboard. :) <br /><br />You might have better luck posting your question in the repair section for your make of motor.
canufixit
Thanks - Just Did ... also,if anyone has "suggestions" or Tips to restore this motor mount without using a chain fall - I'd love the advise ...<br /><br />Thanks !!<br /><br /><br />STeveC
Originally posted by SteveC123:<br /> Thanks - Just Did ... also,if anyone has "suggestions" or Tips to restore this motor mount without using a chain fall - I'd love the advise ...<br /><br />Thanks !!<br /><br /><br />STeveC
Blocks of Wood under the Oil Pan............<br />Careful Jacking between the Hull,+ Oil Pan........
