front motor mount
northvanwatertaxi
I have a 888 mercruiser sterndrive, I searched the forums cant find an answer <br />The engine is out and i'm installing a new bell housing and thrust hub ect i'm doing it in my front yard<br /> the front motor mount is bad but I have another good one. <br />is there anyone that has taken one out?<br />yup she is a salty dog
Bt Doctur
Re: front motor mount
define"front motor mount is bad".usually a cast part with a stud and nut arrangement to adjust the engine alignment.3 bolts hold it in place.<br />888= sb ford?
northvanwatertaxi
yes it's a ford 302, the mount is close to the transom . there are two of them. they are set in a shroud that houses the starter motor<br />My best guess is to take the shroud off and have the "bad" mount pressed down and out then pressed back in
bigbrownbuku
Master Chief Petty Officer
exactly. there are 2 parts that rest on the t plate each side where the mounts sit. make sure they are replaced.<br />edit: not sure but replacement mounts may come without the new washers and instructions on how to fit.
Well,...... Those would be the Rear Motor Mounts,..... Not the Front Motor Mounts............<br /><br />And,........ Yes,.. They're Replaceable..... Press-fit into the Flywheel Cover.........
northvanwatertaxi
Thanks Bondo yes your right.<br />I should have explained the problem better. They must be hard to remove without breaking the flywheel cover
Bt Doctur
they can be,use high heat to melt the rubber and grind out the remaining sleeve,clean the holes with sandpaper,lightly oil/grease,PRESS IN (press/ porto-power/"C" clamp/etc) the new mounts untill seated.
northvanwatertaxi
thanks for the great tips, I will keep you posted, this is the last thing to do. the sterndrive is painted and everything is good to go! Now all we need is some sunshine
northvanwatertaxi
took the flywheel cover to my mechanic he replaced both using a press with a slightly smaller cylender. he said all it took was a lttle heat with a propane torch. I will be installing the engine today
Don S
You better make sure which mounts you have. Merc has new mounts out that eliminates the double wound lock washer.<br /><br />
<br /><br />
northvanwatertaxi
thanks for the diagram Don, i'm just installing the two bolts ,fiber washer now. Just stopped for a break talk about good timing<br />I will make sure everything is right when we use the alignment tool, that should be a good double check
