Re: Front of boat bogging down
As TD says, you're probably a little overpowered there. Most 12' tinnies are rated for 10 hp. So, small trim changes can make a big difference. Trim out one hole and try it out. If it still plows, trim out another hole. As the outboard angles away from the transom, it tends to lift the bow up.
The trim angle will change when you're alone in the boat and when you have a passenger. On my 12' boat, it's a matter of one hole, but that will be different with yours, given the higher power.
Watch it, though. Trim out too far and you'll have a squirrely boat, indeed, with 15 hp on the transom.
