Front switch on 1999 pro craft
titaniumneck
Looking at a 1999 18 ft procraft. On the front deck where the trolling motor plugs in, there where two switches on the plate. I know one of them was the outboard motors tilt/trim relay, what could the other switch be for. There is nothing but an empty hole, and no paint left on the plate to help. From the wear on the plate you can tell there was a switch, but for what? Any ideas.
Could be tilt limit overide (trailer).
A button to press to to allow you to tilt the motor up higher than normal operating range for pulling the boat onto the trailer.
Bannister 6905
No Title
See notes on the attached photo.
Bannister
Drew220
I don't have a procraft but the front panel for my trolling motor has a tilt trim switch, button that activates the tilt trim switch, and a switch that activates a battery guage.
Bannister 6905
Sorry - the switch reads "anchor" and "courtesy". The far right item is a small courtesy light that is activated by the switch next to the trolling motor plug.
Bannister
