front water pump on engine mount
myx17
I have a 1984 glastron conroy X17. I have been restoring the whole boat and today noticed that the water pump pulley is sitting on the top of the front engine mount. I noticed that on the mount its self it says to use the nuts for the trim adjustment. I would I be able to just adjust these away from the pulley or do I need to get a new front mount. Thanks again guys for all the help, and I will try to post pics here soon. Thanks again.
myx17
Re: front water pump on engine mount
Finally got that water pump picture. Thanks again for any help guys !!!
Ayuh,... It appears you have an old Stringer drive,....
I can't help ya with it, But, I'll bump this up for another Go...
myx17
Ok, so I found a break down of the front engine mount on a website yesterday. It turns out that whoever worked on the boat before I bought it did something to the motor mount, and when they put it back together, they put some of the bushings and washers in the wrong place, and in the wrong way. My buddy and I put everything in the right way, and got it running. Runs good for sitting for over a year.
