What is the proper way to adjust the Lean/Rich adjustment on an older style 9.9 Johnson? The knob works, and you can tell a difference when you turn it, but you can pull the knob off, and reinstall at a different setting. Since this engine is new to me, I'm wondering if, after years of use, that it is way out of adjustment? Is there a way to tell? or should just adjust it until the engine runs best at idle? at high rpm?<br /><br /><br />Also, if anyone knows where I can find the rubber boot that covers the stop button, I'm in the market for one.
