kippstakes
- Jun 10, 2013
- 117
Hadn't had the fuel line hooked up in a while, decided to crank the engine on today. Hooked up the fuel connector at the engine and when I started pumping the bulb, fuel started leaking from the line at the connector junction. It should be noted that fuel was also flowing into the filter, so it was working for the most part.
When I disconnected the line, there was a backflow of fuel coming from the male (engine) end out of the filter. I don't recall this happening in the past. Is this normal? Is the problem likely at the male end or female (hose) end?
Suggestions?
Thank you
Suggestions?
Thank you
