Hi Gang, I have had an issue with the fuel bulb not firming up when pumping it. The motor would still start, but last year I replaced the bulb and fuel lines. Issue didn't go away. Motor still starting though until recently when it turns over good, but won't start. I read a post that said it probably was a bad diaphragm in the fuel pump. Today I removed the fuel pump and opened it up. I've included pix, but I see no tears or issues. The fuel filter seems good too. I'm going to replace the fuel filter and spark plugs, but was looking for ideas on what might be the problem. The motor is a 1995 Force 70hp outboard. Thanks!
