Fuel consumption Johnson 15 Hp (j15rsdr)
Does anyone know how much fuel this engine would burn under "normal" operation conditions lets say half throttle most of the time? Reason why is I want to buy a fuel tank for it but don't know what size to buy. 3 gal 5gal 6gal? I like the 3 gal because it fits in a little spot at the back of the boat but don't think it is big enough to run for 3 to 5 hours?
Thanks again
Andy
64osby
Rule of thumb is 10% of HP per hour at WOT. That would be 1.5 gallons per hour.
Running at half throttle would reduce the usage but hull shape, water conditions, wind and weight all play factors.
I would guess a 3 gallon tank would get you 3 hours of use with out running out.
I used to carry a 1 gallon spare container under the splash well on my first boat. Ended up using it twice in 8 years.
