Fuel consumption Suzuki DT50
pianorealm
Hi. Does anyone have an idea of the mpg/galls per hour I can expect from an early 80's Suzuki 50 in good order. Say at 1/2 and WOT?
many thanks
Howard
deejaycee_2000
Re: Fuel consumption Suzuki DT50
At WOT about 3,5 - 4 galls per hour .... at half throttle I unfortunately can't tell you .... I never drive that slow .....
Silvertip
A rule of thumb for determining fuel consumption is to put a decimal point one position left of the horsepower rating. 50 HP = 5.0 gal/hr at wide open throttle. This is a ballpark figure and will vary greatly depending on boat type, weight, prop, etc. Half throttle figure is even more variable as some boats will be efficient at that throttle setting while others may not even plane at that setting.
