Fuel cut off..
mikemarcelle
I have a Yamaha 4 HP with forward and reverse with a built in gas tank. I can't read the model # because the paper label is worn. It is the fuel cut off that the plastic piece on the end of the shaft is broken and won't turn the valve so I have to do it by hand. How can I fix this. Mike.
mikemarcelle
Re: Fuel cut off..
That is it exactly and it is the #32 Shaft that I need and have ordered it. Thank you so much. I know it wasn't muct of a problem but it bothered me that it was broken. Actualy there is a plastic fork on the end that was broken . thanx again, Mike.
