Fuel deck fill grounding
WestPoint
Why do some metal deck fills have ground wire at end of barb. I always used one of the mounting bolts for ground to tank.
alldodge
Metal to metal contact is better then metal to fiberglass contact. The mounting bolts do make contact with, but they are also exposed to the elements. You get more surface contact mounting directly
That said the one in the pic has it down low and the hose will cover it up
