Posted in Pontoons earlier...should have posted here.
I have a Potoon with a 22' gallon tank and a 60HP two stroke 2003 Mercury Big Foot. After some issues with bad fuel and/or water in fuel last year, I added a water/fuel separator in the off season. I had one of those see thru in-line fuel filters already, and I just left it on after adding the separator. Primer bulb is new from late last season and all fuel hose (3/8") is brand new from marine dealer. Checked tightness of all fittings.
I suspect that I'm not getting good flow now and may be running lean. The boat starts fine, but definitely down on power. Additionally, when priming the bulb, it doesn't seem possible to get the primer bulb hard and I'm not seeing the full flow in the see-thru inline filter as I saw last year (without the separator installed). The illustration below depicts the current set-up.
I may go ahead and remove the see thru filter to see if that helps, but I like having it there. Is it common to affect fuel flow with the spin on type separators? The way I mounted the separator, I ended up using inlet and outlets on the same side of the housing....shouldn't make a difference, but wondering if using inlet/out on opposite sides would help.
Advice? Suggestions?
