1997 johnson 50hp vro (disabled when I got motor) Idles all day long, Put it in gear and it will continue to run until you go full throttle and it shuts of. Brought it home run sea foam thru a tank of gas still idles fine. I can go half throttle for a few minutes then it will rev up by itself and shut off without me touching throttle. So im gonna redo both carbs , need the omc part # if anyone knows it (is it 396701?) Is there any other issue that may cause this same problem?
