ND Crownline
- Jul 17, 2012
- 4
I have a 99 Crownline with a 502 Merc. engine Serial # 0L310155 drive number 0L157098 if that helps anyone. My problem is this when the boat is cold it starts and runs just fine. But once I drive it for a while and shut it down and let it sit any more than 30 min. when I go to restart it will start but not run very long and sounds like its not getting fuel. After a few seconds it will stop running then it will not restart at all. I can cycle the key and hear the fuel pump run, and it sound like it wants to start but will not. I can play with cycling the key and messing around with it for 30 min. berfore it will run again. Once it runs again I have no problems unless I let it sit again for more than 30 min or less than 2 hours. I have replaced the fuel pump, water pump, and thormostat and a few other little things, but it still seams like a vacuum lock or something? what else should I be looking at? Anyone had any problems like this before?
thanks for any help or suggestions
