Fuel dilemna
Wes Wyatt
Here's one for ya. I have a 21'center console with a 48 gallon fuel tank. The guage shows full all the time. I pulled the sending unit out and moved the float up and down and the guage registers fine.I put the sending unit back in slowly moved it up and down and the unit and guage works fine. I screwed it back in(poly to poly) after checking for obstructions and it still registers full no matter what the level. Any suggestions? Thanks .......Wes
roscoe
Re: Fuel dilemna
You will reach many more viewers/readers, if you post this question in the "boat topiics " forum.
chuckz
Re: Fuel dilemna
Sounds like you have a bad connection somewhere. I would suggest that as you tighten down the sender it is flexing. The flex is breaking the cicuit. Pull out the sender and try flexing it to see if you can recreate the failure.
