Re: Fuel Filter Before Or After Primer Bulb ...
Before the filter. The cut rubber eventually frays and rots and heads on down the line towards the carbs. The fewer breaks you have in lines between the filter and the carbs the better. On the performance side though a restriction is, for the most part, a restriction. Your fuel pump can overcome it either way.
