Fuel Filter,Water separator,and Fuel pump set up.
cooter2506
Re: Fuel Filter,Water separator,and Fuel pump set up.
Is that an automotive pump and filter?
WAVENBYE2
No it's the origanal, all I did was put the new fuel/water separator in between.
Bt Doctur
what you dont show is the rubber line going to the carb, Mercruiser NEVER had that setup.mount the pump directly to the engine, get some steel brake line tubing, a double flaring kit ,and bend your own.
WAVENBYE2
Exept for the water/fuel separator I left every thing the way it was, here is a picture of the engine, see the pump going to the carb?? I should put the pump closer to the engine using brake line??
JustJason
I don't understand this thread.... is this a continuation of another thread?
WAVENBYE2
OK BT Doctur, I got now, Yes this is the way I bought the boat, I would like to put it back the way it should be, I wonder if the fuel pump is pumping enough to the carb strong enough, I am going to compare pressure while I am at it too, I have a feeling that the engine and or stern drive were replaced, because according to SEI Drives I should have a ALPHA ONE Gen 1,sterndrive, the S/N says it's just an alpha one, Yes it only has two bolts not four, The Alpha one has two. The gen 1 has 4.????? This is a new thread, some one had asked about so I posted how mine was set up,Justin
Thanks again boat Doc for all your help and Info. I will deffinitly put it the way it should be, I do not know the full history of the boat and some things are just not adding up which makes things harder, but with your guys help we do figure it out:).................................Thanks again!!................Pat
