I have a 1967 50 HP, 2 stroke of course, I suspect may be having some problems with ethanol fuel absorbing water. Can a fuel filter/water separator be added to the fuel line on these? If so which one would you recommend?
The answer to your question is yes. Any one will work as long as you have aplace to mount them. I also recommend using Marine Grade Stabil will definatley help with the ethynol
