fuel filter
waldron 1
installing inline fuel filter does it matter if i put it after the primer bulb. want it next to engine to keep it from damage.thank you
KYHunter2
Re: fuel filter
Between primer and tank , thats where it goes.<br /> <br /> It wont work other way .<br /> <br /> Do you have a water seperator / filter ???<br /> <br /> If not , I'd put one in. <br /><br /> Great for peace of mind.<br /> <br /><br /> Good-Luck,<br /> <br /> KYHunter ;)
JC1933
Re: fuel filter
Hi bilge reefer,<br /> I have an in line filter on my motor and it is under the cowling just ahead of the fuel oil pump, came from factory this way. Have a good day. :)
KYHunter2
Re: fuel filter
Jc1933 , <br /><br /> I assumed, from the question asked . <br /><br /> He is installing, a seperate fuel filter. <br /><br /> Not replacing the factory filter/ screen.<br /><br /> If you put any inline filter, between primer bulb and fuel pump . <br /> <br /> You will have fuel delivery problems .<br /><br /> As I said, in my previous answer.<br /><br /> It goes between tank and primer bulb.<br /><br /> KYHunter
