Anyone add fuel liter to there the Chrysler outboard?
We see canister filters being added today, and have seen none on C-OB until the one on the 140HP i got yesterday.
I install small particle filters between the pump and the carbs.
Fram G2 G3 G12 These are see through and easily changed.
One of those will work depending on the hose size.
The newer Forces from 94 up should have one from
the factory.
Before the pump makes the pump work harder.
Most older boats by now have a water separating
filter(or should have) and that catches the big stuff.
The same with the settlement bowl and the filter on
the other pump.
