biglurr54
- Feb 14, 2011
- 234
Im looking at installing a fuel flow meter instead of trying to calibrate my sending unit. It seams like a much more reliable system and it will ave a ton in gas in the long run. The only thing is they are so expensive. I see that Lowrance makes a universal guage that you just hook up a sending unit to and it will give you the info. Has anyone used these.
http://www.iboats.com/Lowrance-LMF-...7526114--**********.428995990--view_id.361223
http://www.iboats.com/Lowrance-Ep-6...7526114--**********.428995990--view_id.356361
For $250 it supposedly works like a fuel flow meter. Does anyone have any experience with these or are there other cheap fuel flow meters. I want one that says how much fuel has been used and how much remains and current rate of use.
