fuel gauge innaccurate - 1978 Mercruiser 165
tony dz
My fuel guage is innaccurate... when the tank is full it reads about 3/4.. best I can tell it's just off by a 1/4 tank, but haven't pushed the low end to find out...
I pulled the sender and manually positined it at the upper limit (metal tab) and it still only read 3/4 full. How do I tell if its a bad sender, bad guage, or bad wire?
I know I saw a thread on this before, but i've been searching for over an hour now and can't find it..
Gary H NC
Re: fuel gauge innaccurate - 1978 Mercruiser 165
First of all clean all your connections with sandpaper,at the sender and the guage. The ground must be clean as well.
I would bet the sender would be the problem..if all the connections are good.
Reel Poor
Disconnect the wire from the sender and touch it to a good ground (key on engine off). If the guage now reads full, the sender is the problem.
Blk-n-Blu
Master Chief Petty Officer
You can probably get a new sender through NAPA auto parts. You will need the tank dimensions, or take it with you.8)
