Can some one tell me what these connection do?
1989 Regal Bow rider 3.7
I'm trying to figure out if I have a ground issue or a gauge issue basically what's going on now is I bought a fuel sending unit the new type that has the sending unit slide up and down this metal post I'll call it. No matter which way I connect the wires when I slide the sensor to the bottom as if the tank is empty my fuel gauge has full if I do the reverse and slide the sending unit upwards it says the tank is empty.
I went to reconnect my old gauge back and now the needle sometimes gets buried well well well beyond full if I jiggle the wires it'll say that it's full when there's actually only about 4 gallons in the tank . But the fact that I'm jiggling the wires got me confused.
I'm going attach some pictures maybe you guys can give me some advice so it's two parts when I connect the new sending unit it reads the system in reverse when I go to put the old good system back and hook it all up the needle goes down to a 5:00 o'clock position of o'clock then I reach underneath the dash again try to start shaking and jiggling things and sometimes it will go back to reading full but again it's not full it's only got 4 gallons . In the picture I see the blue wire should be power for the blub (not power) with test light. Orange wire is the sending unit . Black is ground . What is purple it dasey changes to the other gauges.
