fuel gauge reads empty
jonz
I bought a 96 glastron gs 205 and the gas gauge reads empty is it the gauge or sender how do l test. Thanks for any replies. Jon
MH Hawker
Re: fuel gauge reads empty
the sending unit is tested with a ohm meter it sends a restiance reading to the gage depending on the float position, the gage can be tested by taking off the wire at the sending unit and first checking to see if thier is voltage. If thier is then gounding it will cause gage to change. Be extreamly carfull that thier no fuel fumes present a spark scan ingite them. If thier is no voltage then it can be a fuse or a bad connection or broken wire.
Silvertip
Do a search or just scroll through the electrical forum. Your question has been responded two about six times in the last two weeks. Troubleshooting and diagrams are included.
tpenfield
Maybe the tank is empty ??? :D
SingleShot
Here is a White sheet on Teleflex guages. I hope this helps
ENSIGN
Ground the pink wire on the tank,if the gauge pegs to full it's a bad sender
