imported_Skinny
- Oct 10, 2003
- 7
First off, thanks Arks and Dunaruna for your feedback on my earlier post - it had a typo in it - here's a more accurate and detailed posting.
I have a 1983 Renken and a 1985 Chris Craft. Both have the exact same name brand instruments on their dashboards. The only sign of a company name or trademark on these instruments is a white "T" on the bottom of the instrument faces. The instruments are black and the scales and markings are white and brown. There?s two sets of numbers on the side of the fuel gauge, 1198777 and 3044 under that.
Anyone know what company this is so I can look up the specs? What ohm range the fuel gauge operates?
Does the fuel gauge actually measure a voltage drop or resistance (i.e., ohms)?
THE PROBLEM: The Renken fuel gauge does not work. The resistance between ground and the sender of the tank is 15k . The voltage difference between ground and the sender is 10v, and the difference between the sender and the ignition hot lead is 3v.
I replaced the original ?T? fuel gauge with a 30-240 ohm teleflex (not sure if this is the correct replacement) but the teleflex gauge does not work either. The needle does not move (i.e., reads empty just like the old ?T? gauge did) even though there's plenty of gas in the tank.
Any help would be appreciated.
Thanks, Skinny
Thanks, Skinny
