fuel gauge
cokeman22
so i hooked up my fuel gauge and when i turn the key it pegs full anyone know y??
airdvr1227
Re: fuel gauge
Couple of thoughts come to mind. First one is a bad ground. Second is are you actually starting the engine or just turning the key. Sometimes the engine needs to be running for the gauges to read correctly.
cokeman22
Re: fuel gauge
its when i do both start the engine and turn the key as soon as i turn the key and run it it stays pegged to full
NHGuy
Re: fuel gauge
If it isn't full you need to check your connections.
