Fuel gauge
dino30627
I’ve been redoing my Skeeter bass boat. I went and put the gas tank in half for gas and the tank read full. I pulled the sensor out, moved it up and down. It never came off for full now with the new sensor. If the sensor is hooked up, it reads for when the sensor is disconnected, it reads empty with the sensor hooked up, moving the lever up and down. I can get the center wire which should be power is showing ground didn’t get sprite, and it gives them, depending upon the position of the arm, when checking with a test light, it shows no power at the power wire that when it is connected to the float mechanism I’m lost need any help that I can get I appreciate it. Thank you guys.
dingbat
Senders utilize resistive loading. You need to measure the output in ohms.
