Re: fuel guage not accurate
Fuel gauges read what the sender tells them to read. Senders are designed to read tanks that are square, if the tank is odd shaped all bets are off. <br /><br />Boatin is correct, the float arm can be bent to try to get your sender to read correctly at 1/2, but then you run the chance of throwing the gauge off at F, or worse E.<br /><br />How does it read at E and F now?
