the fuel guage on my '99 SeaRay 210 BR quit working, so I had the local shop pull the sending unit with the idea of replacing it--they checked it out once it was out of the tank and said that it worked fine-sent the right message to the gauge, etc.---now it's not working again and neither are the blower, bildge pump, lights--whatever is controlled by the unitized switch assembly that SeaRay has in the dash. I've checked all fuses in the fuse compartment and they all check out ok--any ideas as to where to check next would be appreciated---thanks, Larry
