eavega
- Apr 29, 2008
- 1,377
Hey folks
So, even though its still boating weather here in Georgia, nighttime temps are staying in the 50s, and I suspect the lake will be too cold for my family fairly soon. I'll get a couple of fishing trips in, but I suspect I'll be winterizing the boat in the next 60 days or so. This will be my second year putting my Stingray away for the winter and I did have a question about fuel and carburetors.
I only run non-ethanol fuel, and during the season I use is quickly enough that I don't think it needs stabilizers. Now, with my previous motors (all 2-stroke outboards) I used to make sure that I ran stabilized fuel through the motor when getting ready to shut it down until spring and left the carb bowls full. I've never fogged the carburetors. For the carbed 3.0 L Mercruiser that's on this boat, is there anything that needs to be done to the fuel/fuel system so that next spring its just a matter of check the oil, fill up the tank (I'll store with an empty tank), fire it up and go? Specifically should I drain the carbs, or is it okay to just leave it be since the winter layup will only be about 4 months?
Part of my end-of-season process will be to change out the two fuel filters (at carb and at pump), check/change the fuel-water separator filter, as well as change out the engine oil and filter and drain the water out of the motor.
I'll also be changing the impeller this year, as its already seen a couple of years of service. As part of this procedure I'll be changing the LU oil and checking alignment before re-installing.
Any other suggestions or advice would be appreciated, especially the question of any fuel-related preparation for the winter nap.
Rgds
Eric
Rgds
Eric
