Fuel in lube oil
Prospector
Merc 60HP Non-EFI Bigfoot 4-stroke
T'stat checked out OK - opened at 120F. Temp. Sensor checked out OK with OHM and hot water test. I'm changing t'stat and temp sensor anyway. Enricher checked out OK with OHM and 12VDC test. Opened fuel pump and diaphragms looked OK but I will change the inboard diaphragm anyway. Could a bad carburetor float cause fuel to leak into oil?
