Fuel in oil, how many oil changes should I do?
I just finally figured out my carb issue and have found a bunch of fuel in my oil. It was up the dipstick about 2-3 inches. I have that oil/gas mix pumped out and fresh oil in it now. Just curious how many times should I pump and fill? And should I keep changing the oil filter each time?
1998 Volvo Penta 4.3GS PBYC
dubs283
Yes
Change it as many/few times as you like
If it were mine I'd change it until the fuel smell goes away
You can reuse the filter, or change it. Wondering if febreze in the filter would help with gassy smelly?
Yes
I never thought about Febreze. I just dumped a bottle down the dipstick hole. No more gas smell. Thank you!
flashback
Fuel mixes readily with oil so one oil change should be good, I'm not certain about fabreeze.
