jguarniere
- Sep 1, 2003
- 9
I would like to confirm the engine fogging procedure for late 90's fuel-injected MerCruiser engines (specifically a 1997 7.4LX MPI):<br /><br />1. Remove the flame arrestor cover, which will expose the throttle body with the dual throttle plates.<br />2. Run the engine (with flushing water) at idle, while spraying fogging oil through the plates. Increase the engine speed slightly if necessary to open the plates further.<br />3. Stop the procedure if the engine stalls, or until smoke is continuously exiting from the exhaust.<br />4. Drain the seawater cooling system and fill with antifreeze.
