Fuel injection for Volvo AQ271
nogin888
Hi Guys<br />Does anyone make a fuel injection for the AQ271(basically a 350 Chevy) Has anyone replaced the carb with a set up and can recommend one.<br />Thanks Nick
nogin888
Re: Fuel injection for Volvo AQ271
Thanks Guys There a big help A question has anyone done the change over and is it worth it?<br />Nick
charleswmoore
My new motor package I ordered fuel injection ($1100.00 option)and heck yeah it makes a difference. Mine was throttle body from V/P and it is the cats a__. A few things change from the way you are use to doing things. The fuel pump is now electric because of the pressure, Also in V/P the fuel pump is water cooled and gas is recirculated within its self.The boat is easily started, very responsive, and very fuel efficent. (72 miles off shore turning 3400 rpm's plus trolling all day was 67 gallons of fuel in a 27 foot eastern with duo prop). If it's in your budget jegs has a marine kit I think in the 900.00<br />range.
nogin888
Thanks Charles<br />The Holly Marine injection looks like it would be the go. Has anyone on Iboats had one installed on a V/P and if so what were the results? Mine is a 91 year built AQ271. <br />Many Thanks Nick
chuck257
hi new to site dont know if i'm posting right spot it would be great if some one could help me thanks. i'm working on an 01 boat with a small block mfi gm has volvo penta stern drive. fixing for a friend boat sat all winter thay pulled out drive changed a bearing & ignition switch boat would not start after thay got done so now its sitting in my drive way. fuel pump only cycles when ignition shut off haven't checked switch yet kinda belive thay installed properly . by passed everything fuel presure a little on the high side pumps are working fuel dose burn checked it with a match pump relay checks ok have 12 volts on one side of injectors cranked engine had pump fed direct off battery was watching ground on other side of injector it never pulled down this thing needs to see ignition pulse need to know how to check that also alarm sounds when its not suppose to . are their any quick checks i can perform on this thing i'm thinking i may have a bad pcm not sure if you could help me out that would be great thanks chuck see ya.
kamby
You may want to post this in a new thread instead of bringing a 6 year old thread back to life. Peeps tend to get confused what the issue is when there is more than 1 issue to a thread.
So welcome aboard. Lots of great people here to help.
