Fuel Issue
greenerob
I have a 1986 Four Winns Freedom with Mercruiser 3.0. I did not use it last year at all because of a baby. I did have it winterized.
I am trying to get it running so that I can use it. It doesn't seem to be getting any fuel. I read in the Seloc manual that the fuel supply valve was to be shut off when winterizing.
Of course it needs to be turned on. The manual makes no mention of it location. Any body know?
90stingray
Re: Fuel Issue
You are going to catch hell for using a seloc manual :) They are only used for kneeling pads, head rests, and to level wobbly tables. anywho, find the fuel line on the engine and trace it backwards toward the tank until you find it. Shouldn't be too hidden.
greenerob
Re: Fuel Issue
Yes, I know it is pure garbage.
I have traced it back, but I can't seem to find anything that looks like it.
Re: Fuel Issue
Ayuh,... Generally speakin', there ain't 1....
Is there gas in the tank,..??
Does the fuelpump, Pump,..??
Have you changed the Filters,..??
