MikeCustomBaitPainter
- Feb 10, 2012
- 81
1988 Mariner 115HP In-line 6
Boat just doesn't want to idle , keeps shutting down , once it shuts down its hard to re-start. Took the crow off & everything is wet with gas ? I wiped everything down put the muffs on & started the motor looking for leaks ? I didn't see anything but notice a few things. (1) I placed my fingers under the top carb where the throttle shaft enters the bottom and it appears gas is leaking from under the carb ? (2) I did the same thing under the middle carb where the throttle shaft enters the bottom of that carb and it appears gas is leaking from under that one ? Does this make any sense ?????
Thanks For Any Help
Mike P.
Thanks For Any Help
Mike P.
